PortailAccueilS'enregistrerFAQConnexionFrégate La Flore (Constructo 1/84°) de Stephen - Page 2 Sans_t13
Le Deal du moment : -39%
Pack Home Cinéma Magnat Monitor : Ampli DENON ...
1190 €
Alex45720
Stephen
marcel47
10 participants
Stephen
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Empty
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyDim 29 Mar 2020, 15:22
Tanks for that, Ekis.I'll continue with the pics you have on Flickr and come back to you if I have further problems.
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyDim 29 Mar 2020, 17:45
There, the files were online: grosfichiers.com/RbmGCSgxRyW
attention, more than 200Mo x3
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Tete50px-56522c4 Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Signature2022-5941241
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyDim 29 Mar 2020, 18:48
Thank you Elkis, you have provided more detail than I ever expected.........and I'm sure I'll find all the information I need within it. Your ship is beautiful with so much added detail....it is a piece of art!
I also have admiration for your workshop and equipment you have......I can only work from a table within my house. I have a workshop outside but it isn't set up for model making.
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyDim 29 Mar 2020, 19:09
Thank you Stephen!
But it was my very first wooden ship, and my first model since I was 14...
There's a lot of pretty average stuff in here, I think.
The main thing is, these pictures might help you!
marcel47
marcel47
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyDim 29 Mar 2020, 20:34
merci pour ce fichier tres utile
Marcel : Embarassed
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 09:17
My latest progress pictures follow. Sorting out the rigging is a slow process but I'm getting there, in the end,Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2015
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2016 thanks again to Ekis.
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 11:13
 Merci de rédiger vos message en français Beaucoup de membres ne parle pas la langue de la perfide Albion sunny
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Captur15
marcel47
marcel47
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 11:15
oui vous avais raison , a chaque fois il faut que je le passe en français
Marcel : Embarassed
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 11:21
Sorry, Marcel and Honey. I previously posted in English with a French translation but I was told that the members on here were more than capable of translating it themselves.I will post with a translation in future.
Désolé, Marcel et Honey. J'ai déjà posté en anglais avec une traduction en français mais on m'a dit que les membres ici étaient plus que capables de le traduire eux-mêmes. Je posterai avec une traduction à l'avenir.
marcel47
marcel47
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 12:50
merci a vous
Marcel : Embarassed
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 13:00
This Flore is really starting to look good! sourire
Good luck with the rest of the rigging.
Are you planning to set sail?
Cette Flore commence vraiment à avoir une fière allure ! sourire
Bon courage pour la suite du gréement.
Est-ce que tu prévois de mettre les voiles déployées ?
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 13:59
Thank you.Yes Ekis, I will have the sails deployed eventually once I have found someone to sew them..........otherwise it will be a slow painstaking job by myself!
Thank you, yes Ekis, I will finally deploy the sails once I have found someone to sew them ... otherwise, it will be a slow and painstaking job by myself!
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 03 Avr 2020, 19:41
Hi Ekis, can you explain what happens to the two ropes leading to 73 & 72 anchorages. The drawing isn't clear and I can't see the solution on any of your pictures. Thank you in advance.
Salut Ekis, pouvez-vous expliquer ce qui arrive aux deux cordes menant aux ancrages 73 & 72. Le dessin n'est pas clair et je ne vois la solution sur aucune de vos photos. Merci d'avance.Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2017
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptySam 04 Avr 2020, 01:09
J'ai regardé sur les plans de l'AAMM.
(1ère image) Ton cordage est attaché sous la hune de grand mât, va tourner sur la poulie du bras de vergue, revient sur une des poulies sous la hune de grand mât, descend vers une des poulies de hauban de grand mât, et va s'attacher à un cabillot du pont (2è image).
I looked at the AAMM blueprints.
(1st picture) Your rope is attached under the mainmast hock (maintop), will turn on the yardarm pulley, goes back to one of the pulleys under the maintop, goes down to one of the mainmast shroud pulleys, and will attach to a deck toggle (2nd picture).
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 P4030011
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 P4030010
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptySam 04 Avr 2020, 07:31
BONJOUR ! oui merci ,miel bonne journee !
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptySam 04 Avr 2020, 09:13
Salut Ekis, merci pour le problème que vous avez pris pour essayer d'expliquer mon problème. Très appréciée. Je vais enquêter sur ce que vous proposez.
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 10 Avr 2020, 13:38
Well, I have finally finished the build except for the sails. I have realised that there is far too much sewing for me to do by hand so I must now wait until the coronavirus lockdown ends and either find someone to make the sails or obtain a simple sewing machine and do it myself. Regarding the ship, I have purposely left some of the ropes long and only temporarily tied so I can re-tension the rigging if necessary after fitting the sails.
Eh bien, j'ai finalement terminé la construction, sauf pour les voiles. J'ai réalisé qu'il y a beaucoup trop de couture à faire à la main, je dois donc attendre la fin du verrouillage du coronavirus et soit trouver quelqu'un pour fabriquer les voiles, soit obtenir une simple machine à coudre et le faire moi-même. En ce qui concerne le navire, j'ai laissé exprès certaines des cordes longues et seulement temporairement attachées afin de pouvoir retendre le gréement si nécessaire après avoir installé les voiles.Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2018
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 10 Avr 2020, 13:52
Elle a de très belles lignes cette Flore !
En attendant d'avoir des voiles, bravo pour la réalisation du gréement. Cool
She has very beautiful lines, this Flore!
While waiting to have sails, congratulations for the rigging.
Cool
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyVen 10 Avr 2020, 13:55
Thank you Ekis........and thanks for your help.
Merci Ekis ........ et merci pour votre aide.
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 13:26
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2027
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2026
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2025
Hi, I have finally completed my ' La Flore' after almost 4 years on and off. I made the sails myself with a 50 euros sewing machine from Carrefour. What to build next............mmmmm?
Salut, j'ai enfin terminé mon «La Flore» après presque 4 ans de temps à autre. J'ai fait les voiles moi-même avec une machine à coudre à 50 euros de chez Carrefour. Que construire ensuite ............ mmmmm?
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 13:32
Here are more pics.
Voici plus de photos.Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2028
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2030
Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 Img_2029
Alexisgm97 aime ce message
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 13:54
Tu as réussi à obtenir un très très beau résultat, et je sais de quoi je parle !
Bravo pour cette belle Flore avec ce qu'offrait le kit qui n'est vraiment pas toujours évident à mettre en valeur... Bravo... Bravo...
Stephen
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 13:57
Thank you, Ekis,for your kind comments.
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 14:30
Bravo! Bravo!
JChristophe LALANNE
En cours : Peugeot 9x8 LEGO
Magellan
Magellan
MessageSujet: Re: Frégate La Flore (Constructo 1/84°) de Stephen   Frégate La Flore (Constructo 1/84°) de Stephen - Page 2 EmptyJeu 21 Jan 2021, 17:29
Bravo! C’est une très  belle réalisation qui met en valeur un bois de qualité dont la couleur blonde  donne un aspect très chaleureux.je suis un peu surpris de voir un pavillon tricolore sur une frégate qui a fini sa carrière en 1785. Est-ce bien le pavillon fourni par Le kit? Le pavillon blanc serait je pense  préférable par soucis d’authenticité .
